Auteur Topic: RS MONITOR- Twingo RS Phase II & Gordini RS  (gelezen 2619 keer)
Offline ReinRacer
  • NEVER GIVE UP !!
  • Clubauto(s): Renault Sport Clio IV R.S. 220 TROPHY Phase 2
  • Lidnummer: 90
« Gepost op: 07 februari, 2013, 15:57:46 pm »
R.S. Monitor - Renault Sport
Designed for the motorsport enthusiasts, the R.S. Monitor application has been developed by Renault Sport to help you measure your performance on circuit. It carries over some of the main functions which makes the integrated R.S. Monitor so special. The R.S Monitor is a popular option on Renault Sport vehicle. In a user friendly way, the R.S. Monitor app lets you record and share key information of your about your circuit laps, whatever car you use.
The R.S. Monitor app will be your best friend on track, allowing you to:
- Measure your acceleration record (0 to 100 km/h – ¼ mile DA)
- Time keep your performance on track over several laps (automatic stopwatch function)
- Analyze the various G forces (Diagram GG) recorded by your vehicle during your laps.
- Measuring the percentage levels PK/Nm
- Measuring the Oil/Brake/Fluids temperatures
- Measuring the percentage levels accelerator/brakes
- Screeninfo about the ultimate gearchange moment.
The app is designed for the purpose of on track entertainment, and we hope that you will enjoy using it safely.
IMPORTANT SAFETY NOTICE
DO NOT USE ON PUBLIC ROADS.. USE THE APP SAFEFLY, ON CIRCUITS ONLY, IN ACCORDANCE WITH THE LAW AND THE REGULATIONS IMPOSED AT THE CIRCUIT. DO NOT TOUCH THE UNIT WHILST DRIVING. RESPECT YOUR VEHICLE’S LIMITS
At all times, drive cautiously and responsibly - priority should always be on your safety and that of the other users of the track. Renault Sport Technologies, RENAULT and other companies of the RENAULT group responsibility cannot be liable for any consequences of using the R.S. Monitor application.
CRS AM-REDACTEUR (nieuws/foto's/interviews)
FLAT-OUT and FEARLESS!!
Offline Laantje
  • Gordini RS
  • Clubauto(s): Clio Gordini RS
  • Lidnummer: 136
Re: RS MONITOR- Twingo RS Phase II & Gordini RS
« Reactie #1 Gepost op: 07 februari, 2013, 19:10:59 pm »
Waarom staat ie bij jou in het frans?
« Reactie #2 Gepost op: 07 februari, 2013, 19:32:52 pm »
Inderdaad, kan hij ook in het Engels. De Franse taal is niet mijn beste kant.  ;D
Offline Laantje
  • Gordini RS
  • Lidnummer: 136
« Reactie #3 Gepost op: 07 februari, 2013, 19:35:44 pm »
Offline Lesley
  • Clubauto(s): Clio 3 RS200 cup
  • Lidnummer: 127
« Reactie #4 Gepost op: 07 februari, 2013, 19:51:54 pm »
Stel je koopt tweedehands een versie waarop het wel leverbaar was, maar waar het niet op zit, kun je het dan achteraf inbouwen ?
Offline ReinRacer
  • NEVER GIVE UP !!
  • Lidnummer: 90
« Reactie #5 Gepost op: 07 februari, 2013, 21:11:08 pm »
Hier nog info van Renault Sport, over de RS -MONITOR
vr. groeten van Rein
@Laantje: het waren foto's van Renault Sport met de introductie
@Lesley: geen idee..misschien even informeren bij je dealer
« Laatst bewerkt op: 07 februari, 2013, 21:30:45 pm door ReinRacer »
« Reactie #6 Gepost op: 08 februari, 2013, 07:39:52 am »
@Lesley, ongetwijfeld, zal alleen aardig aan de prijs zijn. De R.S. Monitor leest zijn gegevens gewoon uit het motor management & abs/esp computer (net als de clip). Klein stukje software er om heen voor de statistieken (0-100, 400m) en klaar is clara.Dus ik kan me niet voorstellen dat dat het niet achteraf zou kunnen gezien die data altijd toegankelijk is.
Offline ReinRacer
  • NEVER GIVE UP !!
  • Lidnummer: 90
« Reactie #7 Gepost op: 09 februari, 2013, 09:47:49 am »
Hier de Engelse versie, en verdere info van het TwingoForum.de.
vr. groeten van Rein.
http://www.twingotuningforum.de/archive/index.php/thread-21470-6.html
Offline Zork
  • Clubauto(s): Clio V6 / Twingo RS Phase II CUP / Clio IV RS Trophy
« Reactie #8 Gepost op: 24 oktober, 2015, 18:53:19 pm »
Hallo,
De Twingo Renault Sport 133 heeft een optioneel 'Renault Sport Monitor' systeem, dat de bestuurder voorziet van real-time data. Je bedient het systeem met de afstandsbediening op het stuurwiel, en via het scherm op het dashboard lees je dan de aanvullende gegevens af over o.a. olie/water-temperatuur, koppel/vermogen/remmen, en kan je de G-krachten en acceleratie tijden meten, met een lap-timer voor op het circuit, compleet met een geheugen-functie.
Begrijp ik het goed dat het voor een Twingo RS Phase II CUP 2012 het 'slechts' een aanpassing van de software (CLIP) inhoudt om dit te activeren? M.a.w. ik hoef de display zelf niet te vervangen? (Voor de volledigheid ik heb een orginele radio met Bluetooth)
« Reactie #9 Gepost op: 31 oktober, 2015, 19:40:04 pm »
Ik denk dat het display ook vervangen moet worden. In mijn RS Gordini van eind 2011 (phase 1) zat geen RS monitor. Ze hebben op mijn verzoek het display vervangen en de software aangepast.
Offline Zork
« Reactie #10 Gepost op: 01 november, 2015, 10:55:05 am »
Bedankt voor je reply!
Ik heb deze week ook nog met Veban Rijswijk gebeld. Zij gaven aan dat het met latere modellen allemaal niet meer zo eenvoudig ligt om softwarematig dit soort zaken te veranderen. De geleverde 'uitrusting'  van de auto is gekoppeld aan het unieke serienummer van de auto en maakt het moeilijker om dit soort zaken achteraf aan te passen? Vrij vertaald kwam het daarop op neer.
Mocht het wel mogelijk zijn dan en iemand weet waar ik dit zou kunnen laten uitvoeren dan hoor ik het graag.
Voor een RS hoort dit er gewoon in te zitten imo.  :P
« Reactie #11 Gepost op: 01 november, 2015, 11:17:45 am »
VKV bellen ?
« Reactie #12 Gepost op: 01 november, 2015, 12:04:21 pm »
Ik heb het bij VKV Gorinchem laten doen, was geen probleem.
Offline Zork
« Reactie #13 Gepost op: 01 november, 2015, 12:12:43 pm »
Ok! Zal volgende week even met hun bellen. Wordt vervolgd dus.
Bedankt voor de reply.
Offline Sven de rijck
  • Clubauto(s): Clio lV RS
« Reactie #14 Gepost op: 28 januari, 2016, 17:00:41 pm »
@ zork is het gelukt via vkv Gorinchem? Via de mail krijg ik voor mijn clio 4 RS het antwoord dat het niet mogelijk is?
